2006 t190
blanddan ยท 2017-01-14 15:29
I have a 2006 T190 when i start up in the morning it runs for about 30 minutes then shuts down. I have to power down and then restart, it will run for about 3 seconds. If i park it for 15 minutes and then start it will run for 10-15 minutes then shuts down again. Any ideas?
Replies8
  1. #1thepumpguysc2017-01-14 15:43
    Do you shut the engine off w/ the key switch or a pull cable?? If its w/ the key switch, I would guess its a faulty shut-off solenoid.. loosing voltage.. or a weak battery, loosing voltage and partially shutting off the solenoid.. OR something in the fuel tank blocking the fuel..
  2. #2blanddan2017-01-14 15:59
    I have a keypad. My first thought possible battery, it is about 3-4 years old, are you thinking battery?
  3. #3blanddan2017-01-14 16:02
    I do not have any error codes on my machine
  4. #4thepumpguysc2017-01-14 16:02
    COULD VERY WELL BE.. Check the tension on the alternator belt.. it could be slipping, not charging the battery.
  5. #5thepumpguysc2017-01-14 16:07
    Does it sound like its running out of fuel, spits & sputters.. Or does it act like you turned the key off??
  6. #6blanddan2017-01-14 19:05
    acts like I turned the machine off. I have buttons/keypad, no keys
  7. #7thepumpguysc2017-01-15 04:35
    Get a cheap volt meter, not a test lite.. check the bat. voltage before starting.. then again while running to make sure the bat. is charging, then again when it shuts down.. IF the bat. voltage is the same or higher when it shuts down, as it was before you started the engine, you can probably rule out a weak battery or alternator. MAKE SURE all your fluids are up to the proper levels..& the alt. belt is in good condit. & tight. If all that checks out, disconnect the solenoid connector.. and look at the connector, it might have corroded, clean the contacts and plug back in.. Those solenoids are REAL BAD about failing, its VERY common.. so if the previous checks check out, I suggest replacing the sol. Its only 2 or 3 screws.. easy.
  8. #8crewchief8882017-01-15 07:34
    if it has the fuel shutoff solenoid with the plug in wiring harness, it's most likely the contacts in the harness and solenoid are "varnished". you'll have to remove the solenoid to see the contacts in the connector. cleaning them may, or may not, "fix" the problem. the bad connection usually burns up the hold coil :drinkup
