I believe its a 2098 or 2048 cant remember mustang skid steer. The problem i have with it is it keeps dying after you start it when you don't have your seat belt on and all the interlocks unlocked. you start it with the seat bar up seat belt off and sitting in the seat all interlocks locked it will start run for about 3 to 5 sec then dye. you sit down buckle up lower the seat bar and unlock the brake lift and tilt and it works fine run around work. If you stop lift the seat bar it dies put it back down you can restart it and run. Or unbuckle it will shut down and lock up. i know the seat bar and seat belt sensors are good the seat switch if you lift up out of the seat when you are running it will also shut down the machine. So what sensor or switch is causing this machine to shut down. I would think if it was a safety switch bad you would not be able to unlock or run with it messed up. its got me baffled any suggestions besides a gallon of gas and a match?
a lighter?
correction its a 2074 mustang dont know the year 800 hours est repo machine
