33ha pin remove
Hotrod1966 · 2023-10-30 20:54
Trying to remove cylinder that levels the basket, I’ve removed top pin working on bottom pin, I’ve removed 1/2 bolt and washer on both sides the pin will move 1/4 inch each way easily placed a 1 inch bolt on it and hit with hammer sounds solid pin doesn’t move. I cleaned with break cleaner and don’t see anything holding pin in. Am I missing something or needing a larger hammer
Replies3
  1. #1Hotrod19662023-11-02 11:49
    Any one, ideas
  2. #2skata2023-11-02 21:48
    Can you rebuild the cylinder while it's still attached to the machine? Usually it's get a bigger hammer, and if that don't work, then torch the pin out.
  3. #3Hotrod19662023-11-02 21:57
    torch and bigger hammer got it out. Thanks
