340D L5X nightmare
seaman sam ยท 2020-07-08 11:39
I received a brand new 340D from Tractors Singapore. The machine arrived full of rust on site. After startup, I realised that the machine was not calibrated properly. They send two technicians to perform the exercise successfully. It did not solve the issue with the stick cylinder . The rod has a bounce of two to three inches in and out of the bottle when you stop the stick movement. After a drift test, they found that the drift test result was within spec. Nether the less, it is now almost a year that they are trying to fix this problem, with zero success. The machine is still under warrantee and has never worked . The main reason for me not using the machine is: When i operate the machine , stick fully stretched out, and pull the stick function in and hold the joystick in the exact same position, the stick will run past a 90 degree angle and then move backwards on its own and then start moving in again. for a certain period , there is no control. I have two videos which I can upload, but cannot manage to upload it here. The only way I can really explain it, is to show the video. Where , or how can I upload it? Tractors were really not help full with this new rusty machine they delivered. Is there perhaps anyone who can assist me ?
Replies0
No replies yet.
