Have a 443B bobcat that is leaking hydraulic on the lift. Looks to be a steel tube line rusted and leaking in front of the battery that lays on the floor in front of the engine. Will the engine need to be removed to replace those lines ??????
yes. as an alternative to pulling the engine, a "low cost" alternative would be remove the leaking tubeline and replace it with a hose.... especially if you are doing the work yourself. :drinkup
Thanks for the reply The rubber hose is how i will go
