DW544HX571646/ 15,250 hrs Trans codes list as 0389/1658/0305 Can anybody help with this code list?
F0305 - TCU Output Speed Zero F0389 - Park Brake Solenoid Open F1658 - Battery Voltage Balance
Of the codes that returned (3) my concern should be The 305 code first? F1658 was repaired when battery was found to be failed due to bad cell. This is where I am at with the machine now.
Yes, concentrate on the 305 code. Does the machine move? A faulty output shaft speed sensor or it's wiring can play havoc with your transmissions ability to operate. Did you check the F2 fuse? I think that sensor gets it's supply voltage from that fuse.
