Hi everyone I have a ld 7775 that will start then stall when you hit the hydraulic controls .I put it in service mode same thing with error code 2 I have bypassed seat swith seat belt switch what am I missing??Note that I have no information whatsoever!!:Banghead
The 02 code I believe indicates that the fuel solenoid has shut the engine down, not necessarily because it is bad. Shutdown was triggered by some other trouble. Did it do this before you tried to bypass the seat belt switch? Might be hydraulic sensor gone bad but should show a light for that also.
