Anyone had many issues with duo seals failing on 789 / 793s? If so, what did you find was causing them to fail?
There is a good thread on duocone seals. One of Nige posts refer to the surface being too smooth causing to ring to spin. The solution was to sand blast the surface.
Installing floating seals Floating, duo-cone, cone, metal face, toric ring, all names used to describe a very old seal design used primarily in undercarriage components, finals drives, and rollers. Recently a thread asked how to properly install floating seals. Installation tools are available, I'm pretty certain a Cat... HeavyEquipmentForums
If you want any sort of sensible answers and/or suggestions you’re going to have to supply a LOT more information.
The toric Orings were reported to have compression set. Would this be due to heat transfer from the brakes?
Again more info required. Hours to failure.? Front or rear (or both).? Who rebuilds the components.?
