8085 jcb excavator 8 ton 900 mmtrack pads
trombeur ยท 2018-08-27 09:58
opinions on 8 ton 900 mmtrack pads, excavator jcb use agricultural farm as service machinery, what do you think, what performance and strength, what excavator would you adopt? thank you 8 Ton JCB Low Ground Presure Midi Excavator Fitted With 900mm Track Pads ,[nbsp]hyd Quick Hitch, Double Acting Hammer Pipework, JCB 8085 Eco Bog Master Excavator?
Replies2
  1. #1trombeur2018-08-28 03:47
    can you tell me the model of jcb excavator single arm tracked bulldozzer dozer blade from 10/12 tons of tonnage before the series of the year 2000 I do not find any model in the mercado of used
  2. #2trombeur2018-08-29 03:30
    jcb JZ 70 ml dozer blade and JCB JS 80 what do you think of for farm use? an excavator from 7 to 10 tons of tracked tonnage with dozer blade, which one would you take? thank you
