I am looking for a wiring schematic or trouble shooting guide for this unit. It runs fine but wont move. If I move the gear selector forward or backward I can hear a relay click in the fuse box. The back up alarm works in reverse. the parking brake light goes off when I release the brake. I have good voltage. Please help, Jim
You have 2 solenoids on the hydrostatic pump, forward and backward, check if these get voltage when you select a direction with the lever. Further troubleshooting depends on the results.
Per, I sent him the SysOp, T&A, & Troubleshooting for the Power Train Electronic Control system plus the electrical schematic.
Thanks, I will start at the pump and work backwards.
Nige & Per thanks for the help. I took apart the forward reverse control box and half of the double wide spring loaded contact was bent down. I restored to contact to the shape of the other ones and smeared the grease around on the contacts. Then I put it back together and tested all the contacts, reinstalled the control and was back in business.
