951c
ttazzman ยท 2010-10-19 23:16
I am going to take a look at a cat 951c 1980modle for a farm machine...i dont know much about the capabilities and possible issues on this older machine any experiences or thoughts would be appreciated......and possible value
Replies7
  1. #1buckfever2010-10-20 17:58
    heavy machines. good for farm use just stay away from soft ground. Their a little slow but will still get the job done.
  2. #2Fred from MO2010-10-21 15:31
    Is this the one by Springfield MO? .
  3. #3ttazzman2010-10-26 12:07
    yes......northview area......do you know anything about the machine?
  4. #4Fred from MO2010-10-29 14:19
    No, saw it advertised myself. If you go look at it and decide not to buy it, would you mind posting on here what you saw? I have a hard time getting up that way. Also if your interested there is a 955H for sale on Craigslist not too far away from Springfield but it sounds a bit worn from what the seller said Thanks
  5. #5ttazzman2010-10-30 15:59
    It came up for private auction today i went and looked at it, it was really a nice machine other than it had one lift cylinder leaking heavily, It had a lot of intrest so i decided not to stay and bid. But i think it should have brought 12k and would have been a bargain under 10k ......it showed and had under 1k hours....salt type tracks....undercarrage i would estimate at 80%+....it had set out so paint/seat etc was rough....lift pins etc were tight...engine sounded great...no smoke.......batteries were bad but jumped it started easily....looked to spent most of its life sitting...wear points showed appropriate rust from sitting...
  6. #6Fred from MO2010-11-01 12:58
    Wow, that was low hours. I didn't know it was up at an Auction. Do you know the Auction house in charge. I would be curious what it went for. Thanks for the response.
  7. #7ttazzman2010-11-02 13:07
    Case Auction in Marshfield MO.......if you find out could you post the info? Thx
