97 jlg 40E
salmonqwiklube ยท 2013-12-14 16:14
low on power tested batteries, bad replaced all 8. repaired charge wire. now shows low charge on battery indicator. flashes red on low side and charger will not turn on. again batteries are testing good. any help please.
Replies1
  1. #1willie592013-12-14 16:19
    Welcome to HEF salmonqwiklube. :drinkup Need more info. Let me take a guess. You replaced all the batteries (you laid out some bucks for that!), batteries were charged, you used the machine (which discharged the batteries some) until the battery level indicator was red, then when you plugged it in to charge it the charger won't kick on. Is that about right?
