Left hand control has no hydraulic power. Right hand lever works ok Hydraulic oil is full. Will only turn right. Any Ideas ?
Lift that side off the ground and move the lever. If the wheels move its likely a weak pump or motor. If you dont have hyd test guages try swapping the lines to the other side to isolate the problem
