1825 case skidsteer start problems
swinedad ยท 2016-09-04 08:41
1825 case skid steer nissan gas engine. When igniton switch is engaged to start position motor runs but if I let off key the engine dies. Where to start? Most likely fix. Thanks for any help. Swinedad
Replies6
  1. #1thepumpguysc2016-09-04 08:50
    Key switch or relay.
  2. #2DIYDAVE2016-09-04 20:29
    Sounds like the key switch has a contact breaking down in it. If not that, then solenoid or relay, wherever the hot for the ignition is picked up...
  3. #3sheepfoot2016-09-04 23:38
    I would do a key switch first also.
  4. #4lazerdan2016-09-05 22:02
    No start Look at the safety switches, seat belt, bar, and all the fuses, look in the book if you can,t find them. Lazerdan
  5. #5swinedad2016-09-06 07:01
    Gonna try switch 1st and go from there. Thanks to everyone.
  6. #6DIYDAVE2016-09-06 20:21
    one thing more, on machines that get a lot of vibration and hit lots of bumps, if you do not have 3 lbs of other keys, and misc junk, the switches last longer...:drinkup
