have a 1985 jd 410b stanadyne pump i think the pump is a #RE57105 dosens of offers for parts but the ones i have ordered don't fit. it had a short selonid and all the new ones every one sales and should replace are two tall and can someone help with a no. can you tell me what no. should i look for incase the pump has ben replaced.
boy this is a old tractor sorry for old finger typing this is for a 1985 john deere 410B.
For sure RE57105 is not the original injection pump. Deere shows no parts breakdown for that pump. thepumpguysc will have to help with that one
A picture of the information plate on that pump is worth a thousand words.
yes got DB2435 5143, 8939396, RE57105, s/n 41230 i will get a pic. when it quits raining. some info about machining top for newer solenoid you get info after buying new part.
All the Stanadyne solenoids r the same.. they increased the size.. it’ll work.. Put on new insulators, red or brown.. then new insulator washers on top..
^^^......and it's that simple folks!
Ta-Da.. I use a little Vasoline on the insulators to help “glide” them thru the cover.. Any questions just fire away.
If u need any insulator lemme know.. I’ll drop’m in the mail..
