I have a 1996 jlb 600s. I have a couple of problems. One is driving. It will only travel 6in then stop. And the steering will only turn right.After looking through the wiring and hydraulic diagrams I was able to confirm that everything is in the correct place. If I push and held the left Turn switch and the breaks release and the unit will drive. The unit will steer right just fine but no left. After switching the coil it will operate left just fine as well. My thought is a bad diode. Hopefully someone can help. Thank you for your time.
No replies yet.
