315SK
Charliemate · 2023-06-11 05:59
315SK “out of range low” error causes park brake to not release. I’ve tried revs but nothing works. Will release after machine running for about 12 minutes then working normally when warm. Trans oil level correct. appreciate any ideas
Replies4
  1. #1mg23612023-06-11 06:08
    Welcome to HEF Charlie ! Lets start with the machine serial number. Then list any codes, either stored or active, from the monitor. List them by their numbers.
  2. #2Charliemate2023-06-11 06:16
    Howdy, here is my serial number, have plenty of stored codes I’ll post them when I’m next back with my machine. Only the one active one at present the “OUT OF RANGE LOW” 1T0315SKCCD236726 Cheers
  3. #3mg23612023-06-11 06:42
    Make sure you list the codes by the SPN/FMI numbers (XXXX.XX).
  4. #4Charliemate2023-06-11 06:43
    Will do thank you
