I've noticed that my2008 ,328 deere when traveling at full forward speed, the right side goes a little faster than the left side. It's a hand control machine, 2 speed. Just wondering if there's an adjustment or something.
Most likely is a adjustment but if its just a little difference don't worry about it, most skid loaders are not perfect. It can change with tire size or even with the slope on the road. Steve
There is a pump bull adjustment on the top of the pumps but it could be the bushings are worn on the centering plate. If you block machine up raise cab you should see “slop” in plates when moving controls. May be able to adjust out but may need some new bushings
