ok guys need some help here im a bit baffeled- 1968 inter 3414 has a front shaft driven pump mounted in front of the radiator that works the power steering and the boom swing both those functions work. also the outriggers work good and pick up the machine with no issues. also the dump on the front bucket still works well but thats it! it has no lifting power with the bucket with out max rpm but its still weak. the backhoe is also very, very weak and slow. there is a cessna hydro pump that is engine mounted and that works all other functions.it has new fluid and ive cracked a bunch of lines and found no dirt or debris. i am joe i would appreciate any info anyone might have!! thank u guys in advance my # is 716-258-1020 if its easier to call then write back
No replies yet.
