553 Bobcat
ColM ยท 2019-06-22 07:53
Where is the chaincase inspection/fill plug on this machine and is there one on each side?
Replies2
  1. #1Bswwood2019-06-22 19:17
    You only have one chaincase and it's in the center of the frame and your fill/inspection plug is front center of the lower frame. Raise the arms and support and you will be able to find it.
  2. #2Bswwood2019-06-22 19:27
    This is what the chaincase looks like, viewing from the rear. #12 is the drain/ fill plug. If you need to inspect chains or brakes you will need to remove one of the top case covers.
