Hey everybody. We got an old 586e case forklift that we just had the pump dropped to change the main motor seal. Got everything back together again, starts fine but it doesn't wanna drive. When I put the lever in reverse the back up alarm doesn't even beep. Also, the solenoid that activates the pump doesn't get any power at all, checked with a test light. Any suggestions? Fuses or breakers I can check? Thanks!
how old? sounds like maybe the wiring to the declutching solenoid has a break or intermittent..possibly broken or pinched during work on the lift. Also check the connector
