648H
Possum Logging · 2020-07-13 05:36
I have a 648H it’s saying on the monitor lock up solenoid the mechine will take forward and reverse and jumps in neutral has anyone had this problem
Replies1
  1. #1mg23612020-07-16 05:37
    How about a serial number and a picture of the monitor with what you are seeing? If you use the menu button and scroll to codes, any codes active or stored? Your description is a little vague. It will or will not go into gear? Goes into gear and pops into neutral right away?
