Anyone know what the brake pressure is it is just a straight 844 sorry don't have serial number and does it have its own brake pump or does it get pressure from some where else
Yes it has a brake pump. It is a gear pump piggybacked to the transmission oil pump.
Thanks
Do you know where the at115276 brake filter is located
There was a serial number break. Machines below 511236 did not use the filter. Above that I believe it is in the pressure line from the pump to the accumulators. Unfortunately the service manual does not show it so I am not 100% sure.
Thanks
