I have a 1998 mustang 2060, went to plow snow the other day, the hydraulics quit and then it quit running, it will start but will only run for a second, and the hydralics won't work. :bash
My quess is hydralic problem somewhere , relief valve maybe , motor will run until it builds up pressure then stalls .
Pressure sensor detects hydraulic charge pressure TO the drive pumps, no pressure it shuts down instead of letting you destroy the pumps.
I have a friend that is having the same issues. He called tonight and asked for my help I’m not real familiar with the mustang skids. Does a guy need to check pump pressures?
