warning light says lift linc position sensor high voltage on my 299D
Easy with the bold text. Welcome. What's your serial number
And what exactly is the Diagnostic Code (in format xxxx-x) you're seeing.? Compare how you asked for help with the way this guy did it. Doing it that way helps us to help you.
how do you pull up codes and i will get serial number thanks
Wherever you saw the message you posted to start off with. Take a photo of what you are seeing on the cab display and post it up if you’re not sure.
299D FD201627 there were several code 3700-3,350-3,458-3 and several more which I think have been resolved
Here are the troubleshooting procedures for all three. Let us know how you get on.
Thanks
