Got an active fault code, 3405-5.Any help troubleshooting this code will be appreciated. Thanks
3405-5 EGR Valve Control : Current Below Normal Troubleshooting: "Motorized Valve - Test". See the attachment.
Thanks for the information. I was able to use the information you provided and make the repair. I can't thank you enough.
Good to hear. What exactly was the problem.?
The EGR valve.
Did you get a response from A on the problem he had. I just got the 3405-5 code on my 324el this morning.
See Post #2 above that contains the troubleshooting procedure.
I removed and cleaned the EGR valve and has been good since.
